Oleg2504 писал(а): ↑23 сен 2018, 15:49
после обновления по пульта, стал тупит голосовой поиск. У всех так, или у меня какой то косяк?
В обнове правили поиск, но русского там не было в описании. Английский, Немецкий и еще какие то языки
Основные изменения в прошивке 04.10.06:
- расширены возможности голосового управления телевизором с помощью Google Assistant (Австралия, Канада, Франция, Германия, Корея, Испания, Соединенное Королевство, Китай) ;
- добавлена поддержка управления тв через умные колонки Google Home / Amazon Echo;
- сокращено время отображения курсора при не перемещении пульта Magic Remote;
- исправлены мелкие ошибки
Detailed applicable model list: Please check with reference Tab exactly
* SW information
1.Improvement
1) Google Assistant is also available in the following countries.
(Australia, Canada, France, Germany, Korea, Spain, United Kingdom)
2) Alibaba voice AI feature is available in China.
3) You can control the TV (channel change, volume control, input switch, etc.) using the Google Home / Amazon Echo Smart Speakers in the following countries as well.
(Google Home: France, Germany, Japan, Korea)
(Amazon Echo: Australia, Canada)
4) We have reduced the amount of time the cursor is displayed when not moving the MRCU.
In addition, Minor Bugs are fixed.
Так же пишут что
My C8 (European version) just prompted me to update to 04.10.05, and of course I went ahead and installed it.
So far I'm impressed with this update because now I can finally use PC mode without several issues.
This is what they fixed (at least what I noticed):
- PC mode without HDR is now perfect with sharpness at 0, no more fuzzy image (with earlier versions the image was either to soft or added sharpness artifacts)
- PC mode with HDR now properly shows 4:4:4 chroma subsampling when using 8-bit HDR with dithering (with previous firmware it dropped to 4:2:2)
- PC mode with HDR seems to properly use the wide gamut color settings (no more need to dial the color setting up to ~70)
