Тест от Игоря (европейского Q80T)amper писал(а): ↑26 дек 2020, 10:42 Между 80Т и 90Т есть разница в работе ШИМ? Если судить по rtings в 80Т можно включить, например, FILMMAKER и в нем не будет ШИМ даже с уплавнялками? Или все-таки ближе к истине абзац из обзора 90Т?
Q80T
This TV uses Pulse-Width Modulation (PWM) to dim its backlight, but since it flickers at such a high frequency, it shouldn't be noticeable for most people. In 'Movie' mode, the flickering frequency drops to 120Hz when Picture Clarity is set to 'Custom' or 'Auto'. The flickering is also at 120Hz when using the 'Dynamic', 'Standard', 'Natural', or 'Game' mode.
Q90T
The backlight isn't flicker-free, but since it flickers at such a high frequency, it shouldn't be noticeable for most people. That said, the flickering drops to 120Hz when in 'Dynamic', 'Standard', 'Natural', or 'Game' mode. In addition, the flickering is also at 120Hz when Picture Clarity is enabled.
https://www.vybortv.ru/forum-o-televizorax/viewtopic.php?f=6&t=6371
